Useless fun
Here N There
Here's 10mm ( Full crop on FX sensor )
Here's a Sony mini memory stick
And here's a dollar ( Lower corners)
Upper Corners
Got a reverse lens ring for a while but never really used it. It's pretty useless.... the workable depth of field is extremely small, so small that the focus mechanism only makes micro/unnoticeable adjustments. With a 20mm prime lens, I have to make micro adjustments by stacking coins and folded paper under the tripod legs. It's more like a microscope at this point because the set up has to be so controlled. It's impossible to use this method to shoot natural macro. Anyways, the ring is cheap and I had my fun.
Man, Those are some Sharply Focused photos! It definitely looks like you had some fun and learned something in the process! :)
Dick
