waterfall reshoot
Carla_
I made it back to this spot before it started to rain. How's this one?
For comparison, here is a link to the original thread from the last time I took this photo.
http://www.thephotoforum.com/forum/nature-wildlife/276534-waterfall-c-c.html
TIA,
Carla
This needs to be redone so it's level water tends to fall straight down, not to the side. also looks like it was not focused tack sharp or their was motion to the camera while shooting.
Looks a bit under exposed and could use a tweak to the contrast. I took it up +.25 and increasd the contrast It's ok to blow out a few highlights when you have a wide range of lighting like this image has and working with a small jpeg file, with the RAW file that could have been worked better to retain the highlights.
Thanks.
How's this one? I adjusted the RAW image.
Carla
I like the 2nd pic the best as far as exposure. I think a polarizer would have been nice as far as galre on the water and it would have made the green more vibrant.
I like Tony S' edit best. It did not need as much editing as you did in the 3rd post, just a small curves adjustment and straitening. Overall, good job.
