Waterworld
davholla
This photography takes a long time but is worth it (if you have the time and patience, you need at least an hour ideally two)
I thought that the first two were of a Cyclops but it might be something similar
Cyclops from the pond. The real size is 2.35 mm, magnification is 3.78
(that is including the egg cases)
CyclopsIMG_7905v7 by davholla2002, on Flickr
CyclopsIMG_7913v2 by davholla2002, on Flickr
Phantom Midge, The real size is 6.26 mm, magnification is 3.08
PhantomMidgeIMG_7923v5 by davholla2002, on Flickr
Very cool, you got me going down the Youtube rabbit hole
Interesting set. I don't know how you photograph such small things in the water but I like it.
For something that looks best from above like the cyclops it is in a small plastic container with a little bit of wall paper paste in to slow it down.
According to this book it does not harm it.
https://www.amazon.co.uk/Extreme-Cl...76&hvtargid=pla-564752804871&psc=1&th=1&psc=1
For the phantom midge I used this
IMG_6802Water by davholla2002, on Flickr
It is two photo frames from a shop called the range, I used a leaf as the background. If I had found a beetle or dragonfly larva I would have tried both set ups.
If I had a lot more time I would do this a lot more, it just takes 30 minutes or so to set it up.
