Patrice
I think we are getting away from what the OP is after. Sure he did ask about dSLR and has done some digging in the secondhand market and has read reviews. However, his problem right now is with getting adequately exposed photos of his computer projects. I suggest that he very likely already has a camera capable of documenting his hardware build. What he needs to do is light it enough to get a properly exposed glare free photo. His flickr has images that show what he's trying to do. In my opinion he is nearly there.
So, JADAWGIS732, try this before you go spend a ton of money.
1. Beg, borrow or steal a couple of those halogen construction lights that carpenters use. They are very bright, way brighter than fluorescents.
2. Get yourself a big piece of white cardboard or foam board 3 feet by 2 feet or so.
3. Position the cardboard in such a way that the reflected light from the construction lights bounces back onto the project you want to photograph, be it a circuit board, an assembly or the inside of a computer case. (Don't get the lights too close to the cardboard, they get really hot!)
4. Turn the flash of your point and shoot off.
5. Hold the camera as square on to the project as you can. Holding the camera at an oblique angle to the project will introduce a lot od perspective errors.
6. Frame or zoom until you have the image you want on the lcd panel and take the exposure. The light are bright enough that you can still use low iso and a fast enough shutter speed to hand hold the camera. If you need a tripod then you'll be ableto make do with a pretty cheap one. Those little cameras are not heavy. Use delayed shutter feature if you do.
Should work for now.
Good luck.
Good luck.
