- Joined
- Jun 7, 2012
- Messages
- 15,504
- Reaction score
- 7,901
- Location
- Central Florida
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #1
Already have a few OEM Nikon flashes (sb600's and sb700's, and some leftover sb24's)
I was in the market for a few extra flashes, mostly for spares and some OCF.
I decided I didn't need (read:want) to shell out the big bucks for more sb700's, or the sb900's so I started looking at third party flashes.
Ive always heard good things about the yongnuo's, so I started my search there. Since these are just spare flashes, i probably could have gotten away with slightly older and much cheaper versions, but I wanted TTL and HSS so....the 568EX was it. not terribly pricy at $170 brand new from an Ebay dealer. shipped from new york with free shipping.
a few things i noticed right away. the color. unlike my nikon flashes which are a glossy black to match the cameras, the yongnuo is a matte black. not really a big deal, its just something I noticed when I put it on the camera. the backlight is orange, not green. It has a pull out diffuser and bounce card like the sb700 does, but they will probably never get used. the menu controls are pretty simple, and easy to use, although you have to hold the power button down for two seconds to power the unit on or off.
at full power, the recycle time on this flash is easily equal to my sb700, if not a bit faster. (i believe its a slightly more powerful flash than the sb700 as well) you can set the flash to one of three modes. manual, multi, and TTL. you have to set the HSS in camera and it is automatically recognized by the flash. for Nikon, this is 250(FP) or 320(FP) under the flash sync menu. once set, the flash will automatically adjust to whatever shutter speed you set it to up to 1/8000. the flash also automatically displays the f/stop your camera is set to, and changes the instant you rotate the aperture control dial.
another interesting discovery...this flash recognizes a Nikon commander flash. if I have a commander flash on the camera (sb700, sb800, sb900) the YN568EX can be set off camera and triggered by the commander flash without a radio trigger. it also has a built in receiver so when i get the yongnuo TTL triggers, i don't need the 568ex on a trigger for it to be fired.
I haven't gone through ALL the features yet. the channels are easy to set, and you can set 4 channels in 3 groups.
I field tested it on the D7100 and ran through a bunch of shutter speeds without any issues with the flash firing or recognizing f/stop or shutter speed.
Just from the initial tests, I would say that this is exactly what I was looking for in a spare/off camera flash. and i could easily see myself just grabbing it for on camera use. As much as I cant praise this flash enough for what I paid for it, it DOES have some cons...
no PC port, so no firmware updates. (just a 2.5mm jack port)
no wireless TTL master mode.
no port for external power supply.
none of those things bothered me in the least. I would not want to put anyone off from getting an OEM flash (we have plenty of them) but for $170 brand new and shipped, i am very pleased, and would recommend this flash to anyone that wants to get a flash, but doesn't have the money for an OEM unit or is looking for extra flashes. of course, if you don't need/want TTL or HSS, you can get an older model a lot cheaper.
I will definitely be ordering more of these. :mrgreen:
