- Joined
- Jun 25, 2023
- Messages
- 658
- Reaction score
- 1,332
- Location
- United Kingdom
- Can others edit my Photos
- Photos NOT OK to edit
Outstanding shot! Am I correct in assuming this done using your macro diffuser? Lighting seems to be spot on,
That is correct, block out any direct sunlight by standing with your back to it, the flash was set on manual mode at 1/32 nd power, you will need to take a test shot or two to get the right exposure...Outstanding shot! Am I correct in assuming this done using your macro diffuser? Lighting seems to be spot on, to my eye anyway.
this fly was taken using the same method, cloudy overcast days are your friendView attachment 274339
macro can be frustrating, expect a low keeper rate at first but stick at it you will improve , practice, practice, practice, start at home , find something small in your junk draw ( everybody has a junk draw right?) set your iso to 200 , sync speed for flash 1/200 depending on camera and and for dof look at f/7 to f/11 , stopping down helps with the paper thin dof that you are working with ,again dependant on censor size...hope this helpsthis fly was taken using the same method, cloudy overcast days are your friend
macro can be frustrating, expect a low keeper rate at first but stick at it you will improve , practice, practice, practice, start at home , find something small in your junk draw ( everybody has a junk draw right?) set your iso to 200 , sync speed for flash 1/200 depending on camera and and for dof look at f/7 to f/11 , stopping down helps with the paper thin dof that you are working with ,again dependant on censor size...hope this helps.
