50mm - 1.8 or 1.4 ????
Discussion in 'Photography Equipment & Products' started by WesVFX, Mar 23, 2010.
  1. WesVFX
    WesVFX TPF Noob!
    Jun 14, 2009
    132
    Hemet, CA
    I'm sure it's been asked before, don't see how it couldn't. But my search didn't really give me results.
    I know the 50mm is sort of a "must have" in your lens line-up, so I'm leaning towards it being my first lens purchase.
    I guess my question is "justification"
    Tell me about the two lenses... is it worth it to fork out the extra for the 1.4?
  2. bitteraspects
    bitteraspects TPF Noob!
    Dec 22, 2005
    813
    honolulu, hawaii
    it really depends on your needs and your budget.
    IME, the 1.4 isabsolutely worth the extra money. you get a much better build quality, faster AF, and better low light performance. the build quality alone is worth the money. ive had a couple of 1.8s break on me.
    but the 1.8 is still by far the best budget lens.
    if youre looking at add a lens to your collection, but dont have much to spend, the 1.8 is a good start. but if you can afford it, i would highly suggest the 1.4
  3. WesVFX
    WesVFX TPF Noob!
    Jun 14, 2009
    132
    Hemet, CA
  4. WesVFX
    WesVFX TPF Noob!
    Jun 14, 2009
    132
    Hemet, CA
  5. jackieclayton
    jackieclayton TPF Noob!
    Jul 18, 2009
    461
    Guam
    if this is your first lens purchase, just try it out and buy the 1.8 for less money... you could always sell it later for nearly what you paid for it if you figure out you need a bit faster lens...
  6. ghache
    ghache No longer a newbie, moving up!
    Jan 25, 2010
    3,570
    295
    I got the 1.8 50mm couple weeks ago and i love it, i did not had the chance to try the 1.4 because it was over my budjet, but in low light, so far i am very happy with it, and for 130 bucks you cant go wrong. i sold my af-s 35mm to get the 50mm, 35mm focal lenght was not doing it for me.
  7. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    I have the f/1.8 because I really don't need f/1.4. The 50/1.8 is just too cheap and too good a lens not to have.
  8. Hamtastic
    Hamtastic TPF Noob!
    Mar 9, 2010
    87
    USA
    I have both. The f/1.8 is obviously a cheaper build, but much of it is cosmetic. No amount of build quality is going to keep the glass from cracking if it hits something hard enough. You don't have to worry about the cheaper 50 falling apart. I've dropped and bashed mine plenty of times. It still works fine.
  9. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    The Canon EF 50mm F/1.8 MKII. This lens is the best bang for the buck lens in Canon line up. But it has limitations. If you are fine with the limitations, it is a good lens. (As least for the price)
    Thess are the limitations I know so far when compared with the F/1.4 version.
    1. Build quality. The lens is not well built. But it doesn't mean it will fall apart anytime soon as long as you take good care of it.
    2. Less shutter blades. The F/1.4 version has more shutter blades so it create a better out of focus background type shots than the F/1.8 version. (8 blades vs 5 blades)
    3. Slower AF speed. The F/1.4 version is a USM lens so the AF speed is faster and quieter. And it has a Full Time Manual Override AF mode. (But I do not mean the 50mm AF is slow, it is faster than some lens I saw)
    4. Plastic mount vs metal mount. It may not make too much difference, but I just like metal mount lens. :)
    5. Depth of Field (DoF) scale. The F/1.4 has a DoF scale.
    6. Manual focus ring on F/1.8 MKII is a tiny little ring which position in the front of the lens. Sometimes it is a little harder to use.
    7. F/1.4, of course it has a wider max aperture than the F/1.8. And because of the wider max aperture, it also help in AF.
    8. According to the MTF data from photozone, optically, they are about the same from F/4 to F/8. But the F/1.4 version is sharper from F/1.8 to F/2.8
    9. Of course, because of the way the F/1.8 version is made, it weight less. But then again, the F/1.4 is not a heavy lens.
    So is the F/1.4 worth the extra? It depends on the person who buy it. It is up to you. Also, personally I think the older version of the 50mm F/1.8 is better than the newer version. I sold my mkII (bought new) and purchase the mkI (bought used).
    The MKI version ..
    1. Has a DoF scale.
    2. Metal mount instead of plastic.
    3. Better build quality than the new one.
    4. Manual focus ring not in the front of the lens.
  10. Hardrock
    Hardrock TPF Noob!
    Apr 8, 2009
    1,173
    36
    Dallas
    I think in the long run you will be much happpier with the 1.4 over the 1.8. Go hold both and see for yourself and I gurantee you will like the 1.4 better.
  11. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    165
    San Diego, CA (RB)
    There is an 8mm difference in the size of the maximum aperture between those two lenses.
    What that means is, with the f/1.4, you have an additional 8mm to allow light in, and that also translates to the lenses ability to produce
    a very thin deph of field.
  12. WesVFX
    WesVFX TPF Noob!
    Jun 14, 2009
    132
    Hemet, CA
    hmmm... thanks for all the input guys :)
    I've come to the conclusion that I'm probably going to hold out for the 1.4
    I'm the type of person that likes to buy the best, and buy it just once. If I can't afford it, I'd rather wait till I could. If I get the 1.8 I know I will always want to buy the 1.4... so an idividual with this sort of personality could drive oneself insane :lol:
50 mm 1.8g o 1.4?
50mm 1.4 vs 1.8
50mm 1.8 vs 1.4
50 1.4 vs 50 1.8mkii
canon 50 1.4 vs 1.8
canon 50mm 1.8 vs 1.4
cual es mejor el nikon 50mm 1.8g o 1.4g
cual tiene mejor bokeh 1.8g o 1.4g
dof 1.4 vs 1.8
