I've been looking at the other ones you've posted from the park shoot. Were you using a polarizer? When your camera's direction was cross-wise to the sun, the sky is pretty dark. When in line with the sun, the sky is light, and when on the 45, the sky is part light and part dark. Not that this is bad, just an observation and I'm wondering if I'm correct.
Probably just depends on the effect you're trying to achieve. I'm trying to get a handle on ND gradients.I was messing around with my CP, yes, and this is always sort of a problem with an Ultrawide Angle lens (my Sigma 10-20 in this case) -- the sky can even change 'blueness' over the field of view (alot of these were shot at 10mm). Good pick-up! I'm still undecided as to whether I should use it at all with this lens.
