advise on a wide angle wedding lens
Discussion in 'Beyond the Basics' started by mheaps, May 16, 2009.
  1. mheaps
    mheaps TPF Noob!
    May 16, 2009
    I am trying to figure out the best wide angle len for wedding portraits. I already have a 50mm 1.8 and a 70-200mm 2.8L IS USM. I want to be able to get a tall building and the bride and groom all in the photo. thanks
  2. photogincollege
    photogincollege TPF Noob!
    Aug 4, 2007
    706
    Grand Rapids, Michigan.
    How much are you willing to spend. And what camera are you using?
  3. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    Some version of Canon since they listed an L lens.
    Canon's 16-35 f/2.8L would be a very good choice but well over $1,400. In between is the 17-55 f/2.8 $925. Next less expensive offering would be the 17-40 f/4.0L $750.
    Maybe even the Sigma 18-50 f/2.8 for $350 if your on a budget.
    Not sure if that is wide enough for you. But would give you more use for normal shooting as well.
    As for ultra wides. Sigma 10-20 f/4.0-5.6 $425. has a really good following. I just got a Tokina 11-16 and so far from the pics I have seen its looking very promising. And it's a fast f/2.8 for $600. But both of these would be limited for just wide shots only. But would give you the ultra wide your needing.
    And Welcome to TPF.
  4. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    I guess the real question is full frame or crop sensor.
  5. haggis
    haggis TPF Noob!
    Nov 6, 2008
    9
    For weddings on a Canon 5D I use 24-70 f2.8 and 70-200 f2.8. My backup camera is a 40D with either the 50 1.8 or 12-24.
    Really is important to know whether you are using FF or crop.
  6. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    I am not sure that your idea would make a good photo. The wider the angle of the lens, the more distortion (lean) you will get in the building and the closer you will need to be to have the bride and groom recognizable in the shot. Depending on camera angle, you may end up even distorting the bride and groom.
    Unless you have lots of experience with wide angle shooting and can solve distortion issues, I would not recommend anything wider than 28mm (full frame equivalent).
    skieur
  7. Lenscap
    Lenscap TPF Noob!
    May 21, 2009
    Sligo, Ireland
    I would suggest a widw angle of no more than 28mm (18mm for small digital sensors) otherwise you will get distortion of the building and the prople. A way around this would be to bring the bride and groom away from the building, so they are no large in the foreground and the building is small in the background. Hope this is helpfull.
  8. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    Without knowing the camera or the budget....
    First choice would be a 16-35 f/2.8. The constant f2.8 is much needed for weddings.
    Second would tbe the 17-55 f/2.8.
    If you are using a crop sensor camera (any Rebel, 40D, 50D) and you are after a wide shot, I'd look at the Canon 10-22mm or the Sigma equivalent. They are not a constant f/2.8 but they will give you the wide angle you are seeking on a crop sensor.
  9. Guido44
    Guido44 TPF Noob!
    Nov 15, 2008
    190
    Near Chicago.
  10. jcolman
    jcolman TPF Noob!
    Feb 15, 2008
    200
    8
    Raleigh NC
    I've got both a 16-35L and 24L that I'll use. The 16-35 (mark I) edges aren't as sharp as the 24, but I rarely use the edges anyway. I also don't normally shoot group shots at 16mm either. I find that 27-35mm focal length works well. Any wider and distortion becomes an issue.
    Another good lens to consider is the Tamron 27-75. I had one for a while, then sold it (the autofocus is slow and doesn't always lock in low light) and bought the canon 24-70. This is a great lens. I eventually sold it to purchase the 24L which is a wonderful low light lens.
  11. jcolman
    jcolman TPF Noob!
    Feb 15, 2008
    200
    8
    Raleigh NC
    There are times however when I wish I still had the 24-70.
    edit: oops, didn't mean to post a reply to my own post!
  12. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    I believe they mentioned that they had a 5D which is a FF, no?
    Sigma makes a few, but I like going all the way. If you want wide, nothing beats a fish eye.
    I picked up a Sigma 15mm F/2.8 prime fisheye:
    [​IMG]
