I see two towers, which appear to be for radio communication, besides several buildings two of which look like hangars. Foreground consists of a chain-link fence topped by barbed wire. Lower quarter of the image is a field of grass, edged by another chain-link fence with barbed wire. Pretty much all the objects in view appear sharp, so a small aperture was used giving a deep dof. Exposure is good, with strong whites, deep darks and a full range of grey tones. Light fall-off at the sky may indicate a polarizer was used to darken the sky. Position of the sun was about 45 degrees to the right, and about the same angle above the horizon.
From a content point-of-view, my eye gets attracted first to the bright roof at the middle of the image, then scans over to each tower, then the lower fence, then returns to the dark hangars at the back. I do not see any visual connection (shape, tone, line) between the elements, other than their proximity to each other visually. The image, in fact can be divided into 2 horizontally, the upper part being mostly empty sky, and the lower part has all the ground-based elements.
Looking at the picture subjectively, the visual prominence is occupied by the two towers, with stuff in between. However, there is nothing in the image which tells me why these towers are there, why they are important to the photographer, or whether there is a context that should be interesting me. As a pattern play, I dont see much pattern. As a shape/texture play, there is some texture and shape, but nothing that I can put together as a pleasing composition. I am not sure what I should be looking at or noticing.
Andrews comments in post #6 shed a little light on what I should be seeing, but the balancing exercise is ruined in my opinion by the mass of dark buildings and bright roof in between, which seem to intrude. The fence appears to be visual afterthought, and does not seem (again in my opinion) to tie in together very well with the towers. Perhaps if the light was from the left and behind the photographer, the buildings would be much lighter in tone and therefore less heavy, and intruding. Some mist or fog would also serve to bring our attention to the foreground elements.
This may be one of those situations when several visits are needed until the right conditions exist to let the vision come through clearly.
