Florin
- Joined
- Jun 19, 2009
- Messages
- 11
- Reaction score
- 0
- Location
- Bucharest
- Can others edit my Photos
- Photos OK to edit
Hello!
The shutters are built by me. You get the shutter tester, a 1.2 meter (4 ft) cable and a 12 page PDF English manual.
About the shutter tester:
- Every shutter tester will be tested before shipping.
- No loose wires. Everything is soldered onto a board.
- The cable is plug and play to allow you to extend it as much as you want and to prevent accidents in case someone trips over it.
- No battery and no maintenance needed! The tester works just like an electret microphone (a microphone that does not need a power supply). I have not heard of any computer sound cards that don't support electret microphones but you should still check if your sound card does.
- Works for speeds up to 1/1000th of a second ( you can find screenshots in the manual with all the information you need).
- Very small and easy to use.
- Needs a computer with a sound card and an audio editor for recording. I recommend Audacity because it's free, portable and easy to use. Also, this is the software used in the manual.
PM me for shipping quotes or if you have any questions!
