Can anyone help / advise ?
Discussion in 'Beyond the Basics' started by Lensmeister, Aug 10, 2006.
  1. Lensmeister
    Lensmeister No longer a newbie, moving up!
    May 1, 2005
    1,489
    14
    This blessed plot, this earth, this realm, this EN
    I took this shot of the Hollywood sign last month but as you can see it's washed out from the haze/smoggy due to the heatwave. This shot was done using a UV filter as well and I can't think how to get the colours sorted out
    Can anyone help please ?
    [​IMG]
    Thanks in advance.... :)
  2. j_mcquillen
    j_mcquillen TPF Noob!
    Oct 3, 2004
    290
    Northumberland, UK
    I could do a quick a photoshop job if you're happy for me to save and edit...
  3. Lensmeister
    May 1, 2005
    1,489
    14
    Oh yes please mate.
    And if you could let me know how to rescure some of the others I shot that day .... Just an outline on how to in photoshop CS would be cool ...
    :hail:
    Thanks
  4. j_mcquillen
    Oct 3, 2004
    290
    Northumberland, UK
    It's a bit rushed, especially around the edges of the tower and hills etc, so I'm sure some clever bu**er with a tablet & graphics pen will be able to do a better job ;)
    [​IMG]
    Technique was as follows (I use Photoshop Elements 4, so it might be slightly different using CS):
    1. Selection of foreground using 'magnetic lassoo' - I then feathered this selection slightly, and saved the selection.
    2. Used levels to correct brightness / contrast / gamma etc for the foreground
    3. Inverted selection, and used levels again to correct the contrast of the background - this helped remove some of the haze. I wasn't worried about the sky burning out, as I was going to create a new one later.
    4. Used 'Colour Variations' to remove some of the blue colour cast of the haze.
    5. Set my foreground colour to white, and background to a nice sky blue, then created a new layer called 'sky'
    6. With the sky layer slected, I used Filter/Render/Clouds to create a blue sky with nice white clouds.
    7. By reducing the opacity of the sky layer slightly, I erased those parts that were covering the land. I then used Image/Transform/Skew to pull the top corners of the sky out and create a perspective effect.
    8. Used levels & hue/saturation to improve the colour of sky layer, and reduced its opacity slighty to blend it with the background.
    9. Flattened image, final check of levels, then a little sharpening.
    Hope you like! :D
  5. Lensmeister
    May 1, 2005
    1,489
    14
    Excellent thanks a lot .
    I'll print off the instructions at work tomorrow : ) :) :hail:
    Cheers
  6. Luke
    Luke TPF Noob!
    May 9, 2006
    159
    polarizer filter helps here too, it will reduce the moister thats apparent in the air.
  7. bigfatbadger
    bigfatbadger TPF Noob!
    Mar 19, 2006
    464
    Nottingham, UK
    The levels in photoshop are heavily influenced by the presence of the foreground, which is well exposed.
    Use the magic wand / selection tools to select the 'hazed about section' (or select the forgeround the select -> inverse and then adjust the levels independently.
    Does that make sense? All useless if you don't have photoshop of course
  8. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    Heres my quick edit, no funny sky's though, done in PS layers [​IMG]
