Natty36
- Joined
- Jan 13, 2015
- Messages
- 5
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
ll thanks for respondingI would attempt it but don't have the time currently.
I will say that that's a lot less simple of an edit than you may think. It could take a long time to pull off properly.
Actually, that's NOT a simple edit, and there's virtually nothing that can be done with an image that small. If you have the original full-resolution file, someone might be able to touch it up a bit...
View attachment 93126Actually, that's NOT a simple edit, and there's virtually nothing that can be done with an image that small. If you have the original full-resolution file, someone might be able to touch it up a bit...
Precisely; I didn't make myself clear.I don't think it's the size of the "picture" that's the problem. It's the size of the "file" that matters.
ks!The photo is made in a very low pixel count. It should be at least 2 or 3 hundred pixels per inch to provide enough material to work magic on. Here's a quick fix.
yeargh! that's terrifyingThe photo is made in a very low pixel count. It should be at least 2 or 3 hundred pixels per inch to provide enough material to work magic on. Here's a quick fix.
