Looking directly at the sun with your naked eye is a bad idea even with sunglasses, unless the sunglasses double as a welding mask, and whatever you do don't zoom in on the sun whilst looking through the viewfinder.
The best Gunfighters always kept there back to the sun for a reason!
As welding glass is designed to block UV & IR to at least the same extent as the visible it's safe to use, but you should use high factor welding glass if you've got any magnification.I've heard people say they used a welders mask to shoot through to take sun pictures. Never tried it myself.
I've been interested in the solar spectrum profile since it impacts some of the work I do. There are many sources accessible on the internet that show the solar spectrum as a distribution of energy by wavelength. One such graphic is File:Solar Spectrum.png - Wikipedia, the free encyclopedia
In summary, about 53% of the energy of the light from the sun is in the infrared portion of the spectrum, with ultraviolet making up 3% and visible light making up the rest (44%).
We all know how a little optical aid (magnifying glass) can concentrate enough sunlight to cause burns (wood, paper, etc.). The same effect will happen in the eyeball. Fortunately, when the sun is close to the horizon, almost all the UV is filtered out by the atmosphere, which is why we can usually admire the sunset without going blind. Even then, when I shoot the sun, I use the camera's live-view function to avoid any possibility of seeing sunlight concentrated by the optics.
