can you tell me about medium format?
Discussion in 'Beyond the Basics' started by nikon90s, Jul 11, 2003.
  1. nikon90s
    nikon90s TPF Noob!
    Jul 5, 2003
    581
    Kalispell, MT.
    I know nothing about this format can someone tell me a little about it :roll:
  2. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Umm... it's bigger than 35 mm, so the negs are bigger, so the quality of enlargements is finer? Heck, that's about all I know! Next! :D
  3. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Well medium is in the middle of the designated formats.
    35mm is small
    6x4.5, 6x6, 6x7, and 6x9 are medium formats. Medium format uses roll film and the #s are in cm.
    Large format is 4x5, 8x10 and up and the #'s are in inches. They use sheets of film.
    645 and 6x6 are the most popular of the format. The larger film captures quite a bit more detail. It allows you to also enlarge photos much larger than 35mm.
    I'm sure others will add more.
  4. manda
    manda instigator of pottymouthedness
    May 25, 2003
    3,330
    11
    sydney
    They are a bugger to load!
  5. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    not as easy to load as 35mm...
    but I'm sure a Holga is going to be tougher to load than an SLR or TLR.
  6. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    ...... itinerant ..........
    ...a few more things:
    * an advantage with medium format cameras (MF) is their interchangeable backs - film is loaded into a separate compartment which then clicks/attaches onto the camera. This enables you to change film type at any time, say, from B&W to colour neg or transparency, even Polaroid, halfway through a roll
    * Digital backs may also be used (horrendously expensive!) and the image directly downloaded to computer for instant viewing and "save"
    * MF cameras have leaf shutters in their lens (or the option of) which are simpler to use with flash - no limitations with sync' speed
    * MF cameras have a choice of viewing systems - including waist level viewfinders, prism viewfinders, rotary finders and interchangeable viewing screens (only some 35mm cameras have these options)
    * There are also SLR-MF cameras with all the above features
    * TLR (twin lens reflex) MF cameras do not have interchangeable film backs and, except for the Mamiya C330, do not have interchangeable lenses
    * Some disadvantages are - their weight, no TTL metering, extra cost per shot and they do not have the range of lenses and accessories available for 35mm cameras
    Until the advent of digital, MF cameras were the mainstay of studio and professional shooters
    These days good second hand models are available at reasonable cost
    I had fun learning about them and using them when training, but haven't picked one up for years
    e_
  7. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Actually, there are Rolleiflex models that have interchangable lenses. For the Yashicamat, there is a telephoto and wide angle lens. It might be more of a converter, not sure...
  8. Westone
    Westone TPF Noob!
    Jul 3, 2003
    19
    Oregon, USA
    Hello
    I used a Pentex 6X7 for a couple of years. I sold it and went back to my 35mm Nikkor gear. Reason? I found that the prints from my Nikkor gear gave me as good a print as the larger negs. 90% of my wall prints are 11X14. I have many at 16X20, and a few much larger. All from the 35mm format. With slow film, a good tripod and cable release, the 35mm from a good camera will be hard to beat. If you check out the price of the gear for the larger format ..... well ..... if your going to do huge prints, it might be worth the expense. Good luck
    Chuck
  9. MDowdey
    MDowdey Guest
    Expensive as hell!!!
    leave that to the big boys i will... hey that sounded like yoda. awesome.
    md
  10. nikon90s
    nikon90s TPF Noob!
    Jul 5, 2003
    581
    Kalispell, MT.
    Westone,
    I will try and blow up one and look for my self, I just got a roll of 135 speed film and they are getting developed as i type. I used a tripod but don't have a cable release yet. I have looked at getting one but the only one I found that would work with my N90s costs over $80.00 and for a cable release i just had to let that one soak in for a few days then look on the net for a cheaper one. I will let you all know how my experiment works out.
    nikon
  11. chris
    chris No longer a newbie, moving up!
    Jun 20, 2003
    281
    28
    Scotland
    If you don't have a cable release then use the self timer - if you don't need to to take a shot at a precise moment then it should be at least as good as a cable release for preventing unwanted vibration of the camera.
  12. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    ...thanks for picking me up on that, voodoocat
    Nice one!
    e_
