Cannon AE-1
Discussion in 'Beyond the Basics' started by heykaren, Jan 9, 2004.
  1. heykaren
    heykaren TPF Noob!
    Jan 9, 2004
    4
    I have an old Cannon AE-1 that isnt working perfectly but has done me some good service. Recently, Ive gotten the urge to drag it out and try to get some creative photos taken, but the camera will work when there is no film in it - the shutter works when the button is pressed - but doesnt seem to want to work when there is film inside. Has anyone had a problem like this - is it fixable, or is it time for a new camera. Thanks!
  2. .glib
    .glib TPF Noob!
    Jan 6, 2004
    9
    Hmm... I've got the same camera, but don't know the problem.
    If it's just been sitting around for a while, you make want to take it in and get it cleaned, oiled and fixed up before you start heavily using it.
  3. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    I agree with glib. Take it in for a good cleaning, and ask them to check it out and give you a price to fix it.
  4. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Is the battery new? Try to replace it and see if that fixes the problem. Also, does the counter move when shooting without film? Or is it stuck at 36?
    I believe it is a fixable problem, I'd start with a new battery and then take it for a good CLA (Clean, Lube and Adjust). Depending where you take it, it might be better buying another gently used body for a few more bucks.
    Good luck.
  5. heykaren
    heykaren TPF Noob!
    Jan 9, 2004
    4
    Thanks for the advice! The counter does move when there is no film, it is not stuck on 36. I will try the new battery first --- I cant remember the last time I changed it. Hopefully it will be a simple thing - everything I see now Im looking at as "that would make a great photo" -- Im dying to get out there and shoot. Ill let you know how it turns out! Thanks again! :)
  6. Mitica100
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Cool! Can't wait to see your pics. :D
