Canon 40D popup flash Commander ?
elrafo
montreal
Website
el-rafo.deviantart.com
Hello!
My brother bought a 40D and seems like there are no options to use the Popup flash as commander for Wireless flash...
I think it is a bit strange for this kind of semi-pro camera, would you be able to give us some advice on this option ? does he have to buy a wireless trigger additional? what are the Canon flashs that can be used as slave with the camera?
thanks!
Commander mode is a Nikon terminology, let's not get stuck on them too much.
All the OP is looking for is if his 40D can have the built-in flash preset to a manual mode so that it can serve as the trigger for an off camera flash via optical trigger.
I don't know the answer, since I am one of those Nikon people... lol.
Did you check your camera manual and see if you can set your flash to manual or not?
elrafo,
I have some bad news for you:
There is no such thing as commander mode built into a Canon camera. Not even the Canon 1Ds Mark III (an $8000 camera) have that! Someday maybe, but not today.
Unlike all the Nikons you have seen, with Canon the built-in flash cannot act as either master or slave for anything. It is just a flash, nothing else, and many (all?) high-end Canons don't even have one! Within the Canon system, the wireless flash is achieved either with an external on-camera flash capable of being a master (e.g. the 580EX) for ANOTHER off-camera flash capable of being a slave (e.g. the 480EX), or with a dedicated wireless transmitter, the ST-E2, which then drives an off-camera flash set as slave. These are the only Canon options, and needless to say, they all require you to buy something extra.
Apart from that you can just have a wireless trigger (no E-TTL) for an off-camera flash using gadgets like Pocket Wizards and such. There is tons out there, I will let you figure out the one that best suits you.
I hope this helps.
That's correct. Canon doens't have any 'built-in' master flash capabilities.
There are plenty of threads around here about 'off camera flash' and you should also check out http://www.strobist.blogspot.com/
Yikes!
Now I learned something new. That sucks guys!
