Thank you for your replies.
I didn't say they are. I just meant I found cheap cameras that have CCD sensor but can record a video at 25-30 fps. The reason I mentioned fps because a little older or cheaper models I had found before couldnt record hi res at higher than 15 fps.Frame rate and shutter speed are different.
So my question was, is there anything wrong with using these kind of cameras for my task? Like "Canon PowerShot A3350 IS"? Again, I'm a noob at cameras. I've found a camera that I can use to record lasers and it *seems* to work for me. But maybe there are some other factors I don't know which makes using these kind of old cheap cameras having a CCD sensor not a good idea.
English isnt my first language so I hope I can explain what I want to know.
I've tried setting the shutter speed to that.If you know what hertz the lasers are and set the shutter speed according to that you should solve the problem. For example office fluorescent light are 60 hertz so setting the shutter speed to 60 or 125 will make it so there is no flicker.
In fact I'd be willing to bet if you set the shutter speed to 1/60 you'd have no issues.
The problem is not flickering effect.
With lasers it's kHz, not Hz, so I think that's why it doesn't help. The galvanometers (mirrors) can move the laser beam at kHz speeds and the brightness/color of the beam can be changed at kHz speeds.
