- Joined
- Jun 25, 2016
- Messages
- 688
- Reaction score
- 783
- Can others edit my Photos
- Photos OK to edit
Hey, I got a day off and would like to try this today. Look back at all of my pictures that are shot with my 135 the focus is always in front! How far should I set this book up and do I need to use widest aperture? ThanksWhat lens did you use? If you picked a single AF point, it can mean you're facing a problem with front-focusing lens and a simple calibration should help you. In all your shots your focus is clearly in front of your subject.
You can easily test for this using a tripod, picking a single AF point and observing your resulting photos. Also make sure you're testing with inanimate objects, so you rule out any human errors. For instance some slightly angled book is a good test subject. Try to focus on a specific letter/word and it has to be sharp. If it's not, you know you have to calibrate it. As you have 6D, you probably won't even need to visit a service center for that (you can adjust this from the menu in your camera).
