Color filter plugin?
In Photoshop CS, click 'Image/adjustments/photo filters' You can select from a whole list of photo filters.
Or if you are converting a color photo to b&w, you can use color adjustment layers to get the same effects as using color filters on the lens.
I've read a few different methods...search around, I'm sure there are plenty of explanations that would be better than anything I could put together.
You can use the Channel Mixer to change how different colours look when turned into B&W.
Layer -> New Adjustment Layer -> Channel Mixer
Then Select the Monochrome Box
Then have a play with the different levels of your different colours.
I have a tute for an Orthocromatic look if you want it. (great for blues/greens, crap for reds/oranges.)
