Compact Flash problem and question
Discussion in 'Beyond the Basics' started by Patrick, Apr 13, 2004.
  1. Patrick
    Patrick TPF Noob!
    Oct 2, 2003
    562
    Xenia, OH
    Here's one for you.
    What's the lifespan of a compact flashcard?
    Reason I ask is that one of my 256 cards has seemed to have bit the dust.
    Took some photo's, used a card reader to up load them to the computer and when I put it back in the camera I got an error. Even tried using it with the computer again and it wouldn't read it either.
    Bout 1.5 years old and maybe 2000 clicks and movies.
  2. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    That seems a little odd, I have 2 1gb CFs and have taken over 8 thousand shots since last July. Is it a microdrive? I have hear negative thinks about them.
  3. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    Yeah, A microdrive card is basically a mini-hard drive. If you drop it, you can wreck the mini-disc inside and ruin the card.
    As far as any other CF card, they are solid-state, and should be much harder to kill.
  4. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Did you try formatting the disk?
  5. Harpper
    Harpper TPF Noob!
    Feb 4, 2004
    810
    USA
    If all else fails most cards have a several year warranty, but it's weird that yours died so soon. What brand is it?
    While we are speaking of brands does anyone else notice the fit sizing difference between certain brands? I have a Lexar and a SanDisk compact flash card but the Lexer seems to fit smoothly into the CF slot whereas the SanDisk kind of grinds its way in. It feels as if I'm damaging the camera because I have to force it in and I can literally feel the grinding while I push it. At first I thought it was just the SanDisk card I got but I was able to try another one only to have the same problem. Am I the only one?
  6. PhotoJoe
    PhotoJoe TPF Noob!
    Mar 7, 2004
    46
    I had a similar problem with a Lexar Fire Wire reader, and a SanDisk 1 gig CF card. No answer though as to why.
  7. Harpper
    Harpper TPF Noob!
    Feb 4, 2004
    810
    USA
    So it's not just me. I think SanDisk might have its measurements off by about a millimeter or so which makes for a tight squeeze. It's too bad because SanDisk has some pretty good reviews but Lexar has good reviews too. I guess it looks like I'm just going to have to use other brands for now.
  8. PhotoJoe
    PhotoJoe TPF Noob!
    Mar 7, 2004
    46
    Which brands will you try? Will you swap the drive first, or the card, or both?
  9. Patrick
    Patrick TPF Noob!
    Oct 2, 2003
    562
    Xenia, OH
    It was a Lexar 256mb (so they say..LOL always showed 248MB) 12X
    I tried reformatting it in the camera. When I try it on the PC, everytime I try to access it all I get is the hour glass thing and an error message about 4 minutes later.
    I'll try sending Lexar an email but I have no idea where the sales reciept would be. Guess I should start saving those :cry:
  10. Harpper
    Harpper TPF Noob!
    Feb 4, 2004
    810
    USA
    The only thing I can do is get a different brand because the CF slot I'm talking about is on my camera. What I'll most likely do is take my camera into the store and try out some cards to see how they fit first before I buy.
    So far my Lexar is working fine and I'll let you guys know if there is a problem. The SanDisk also works fine except that it requires more nudging to get in compare to the smooth fit of the Lexar. You guys can also read CF card performance reviews at
    dprview and make up your own minds.
    Patrick I don't know what you tell you. Failing compact flash cards are pretty rarely. Well, at least I haven't heard many complaints. Of course, anything manufactured will have some bad batches. I think you might have just been unlucky. Lexar also has some kind of image rescue software. You might want to check that out if you really want those pictures.
  11. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    5
    Pasco, WA
    Harpper- I have the same issue with my istD. My Lexar 128s fall right out, I had to put tape flags on my Kingston 512s. [shrug]
  12. Patrick
    Patrick TPF Noob!
    Oct 2, 2003
    562
    Xenia, OH
