Converting a single channel to an image
Discussion in 'Digital Discussion & Q&A' started by awe, Apr 28, 2008.
  1. awe
    awe TPF Noob!
    Feb 23, 2007
    83
    Hi there,
    sometimes, when I want to convert an image to black and white, I'd like to use the tone information of a single channel (i.e. what you see when only one channel is visible instead of all three in RGB) as the final picture or the starting point. Here's how I usually do it:
    - Make a new layer and fill it all white
    - Load the channel as the current selection (i.e. Control-Click on it).
    - Invert the selection and fill it with black.
    However, this is rather tedious. I could make an Action out of it, but I was wondering if there is an easier way...
    Thanks!
  2. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    What software are you using? I just use the Channel Mixer in Photoshop. You can easily create a monochrome image from whatever mix of channels you want.
    Best,
    Helen
  3. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,336
    16
    Caribbean
    The channel mixer, like Helen said, is probably your best bet. There is also a black & white converter under the adjustment layer menu that allows you to do the same thing, except you can do magenta, cyan and yellow as well if you want more options.
  4. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    You can, of course, use the Channel Mixer for magenta (R&B), cyan (G&B) and yellow (R&G) conversions to monochrome. You can also subtract one channel - you could do a conversion that was +200% red -100% blue, for example.
    Best,
    Helen
  5. awe
    awe TPF Noob!
    Feb 23, 2007
    83
    @Helen:
    D'oh! That was exactly what I was looking for. Thanks a lot! Wow, and I thought I knew PS...
cvset single channel image
image single channel
mapnik image single channel mangled
one channel black image
single channel images
single-channel image
single-channel images
what is a single channel image
what is single channel image
