CPL filter for my Tamron 18-250?
Discussion in 'Photography Beginners' Forum' started by triumz, Apr 11, 2008.
  1. triumz
    triumz TPF Noob!
    Apr 6, 2008
    4
    I don't really understand about filter. If i buy a 55mm CPL filter, is that means that the filter for 55mm lens only...
    Thanks...
  2. evo5gsr
    evo5gsr TPF Noob!
    Feb 6, 2008
    131
    Bay Area
    Look for the symbol that looks like a circle with a diagonal line crossing it. That's usually under the lens cap or the front of the lens itself. A number should precede that symbol. That's the filter size you need.
  3. Mystwalker
    Mystwalker TPF Noob!
    Jan 25, 2008
    544
    Apologies in advance if I am oversimplifying ...
    A "55mm filter (CPL, UV, ND, etc ...)" is not necessarily for a 55mm lens.
    The 55mm is the diameter of the lens - I think. It is not the "length" of lens.
    ex: I have 77mm filter for my 70-200
    I have 52mm (I think) for my 28-135
    I have 77mm filter for my 17-40
    The 70-200 lens and 17-40 lens happen to have the same diameter while the 52mm is smaller.
    The Tamron 18-250 ... is it this one? http://www.bhphotovideo.com/c/product/477062-REG/Tamron_AF018S700_AF_18_250mm_f_3_5_6_3_Di_II.html
    If you go to specs for that lens, it will tell you that the filter size is "62mm". Filters you can use are also on that page. B&H makes it easy :)
    Hope this helps.
  4. KhronoS
    KhronoS TPF Noob!
    Oct 8, 2007
    345
    Romania, Galati
    That 55mm is the diameter of the filter and fits with any lens that have the same 55mm diameter. :)
  5. triumz
    triumz TPF Noob!
    Apr 6, 2008
    4
    Thank You Guys... :)
    I'm ready to search & shop now :D
filter size of tamron 18 to 250 lens
