D40 stock?
Discussion in 'Nature & Wildlife' started by Markw, Sep 29, 2008.
  1. Markw
    Markw No longer a newbie, moving up!
    Jul 25, 2008
    4,051
    231
    Baltimore
    Does anyone have shots taken with the D40s stock lens without any PP? I would love to see them as examples.
    Mark
  2. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    Sorry, didnt realize I posted in the wrong thread/forum.
    Mark
  3. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    Ok, well lets restate that and say any nature & wildlife pictures taken with the stock lens.
    Mark
  4. TrickyRic
    TrickyRic TPF Noob!
    Jun 1, 2008
    264
    Toronto, ON, Canada.
    I still use my 18-55mm Nikkor for close up shots and have no problems. What troubles are you experiencing?
    My post processing generally only extends as far as recrops, dust removal, and the occasional exposure enhancing that comes from stubbornly refusing to work with Flash unless absolutely forced to do so. My shots can be found at http://picturepostbox.com/TrickyRic/1/profile.php or http://trickyric.etsy.com.
  5. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    Not any. I am deciding whether to buy the body and different lenses or the body with the lens and buy more lenses ontop of it.
    Mark
  6. TrickyRic
    TrickyRic TPF Noob!
    Jun 1, 2008
    264
    Ah I see.
    I use the standard 18-55mm Nikkor that comes with the D40, and a 55-200mm matching lens. These days you can get the 200 in a VR model but at the time of my purchase it wasn't available. To this date I've had no need for a longer range lens and since I'm mostly a nature photographer, the specifications of both lenses are fine 99% of the time. For the price, I don't really think you can go wrong with Nikkor.
    Be warned however, that you'll likely find yourself switching lenses more often than you'd like. If you're not comfortable with the greater risk of having to clean your camera sensor and you don't mind paying some extra cash and carrying a heavier lens around, you might want to look at the 55-200 Nikkor or similar.
    Oh, and it's worth noting that 18-34mm isn't nearly enough of a range to take decent wide angle shots. It's really only useful for close up shots. If you want to dabble with wide angle, you might want to leave out the 18-55 entirely and get say a 28-200 lens and a wide angle lens.
  7. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Image quality has more to do with lenses and the thing behind the camera than bodies.
    Huh? That doesn't make very much sense. 28mm is wide on a full frame, but not on a crop frame. 18mm is when things start to get wide on a crop frame.
  8. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    I agree - really good lenses are worth far more than a really good camera body!
    Though for the record one should never fear changing lenses whilst shooting - you are using an SLR camera for the advantage of interchangable lenses so take advantage of it. Modern editing can take out most dustspots with ease - and if you are in a horrible situation (like a duststorm) then just use a small bag held over the kit whilst you change and you should be fine.
    For nature so far all I have is my 70-200mm and a 1.4 teleconverter - I find that a very good combo when in zoos and sactuaries - out in the field I find it a little short (one needs very good fieldcraft skills to really get those closer shots). 300mm is often the best or most used wildlife focal range, though if you are looking at a 300mm lens with zoom you really do need to be careful since many of them are cheap end lenses -- made to do a lot for very little - and thus are generally soft lenses.
    And yes your kit lens will be fine for landscape shots - the only step up would be something like a 10-20mm sigma lens for some really wide angle shots,
  9. TrickyRic
    TrickyRic TPF Noob!
    Jun 1, 2008
    264
    I was meaning that for wide angle photography, 18-34 doesn't get you very far. I use my 18-55mm lens for close up shots, i.e. shots where the subject is right in front of you and you need a sharp focus.
  10. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    So any opinions on the sigma or tamron 70-300 lenses?
    Mark
  11. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    bump.
    Mark
  12. epp_b
    Aug 22, 2008
    2,135
    12
    Oops, sorry, I misread your comment. Forget it :)
    Although, I still don't get what you're trying to say here:
    Anyway, the 18-200mm has gotten great reviews and it's a fantastic range to have all in one lens. 18 is reasonably wide on APS-C and 200 is good general-use telephoto.
    Nikon makes a 70-300G lens for $150 MSRP. It won't AF on the D40, but I'm considering it myself just because it's a decent telephoto lens for so cheap. Apparently, it makes for a great lens as it goes soft between 200 and 300mm and has a rounded, 9-blade aperture.
