Trever1t
- Joined
- Dec 30, 2010
- Messages
- 9,331
- Reaction score
- 2,722
- Location
- San Jose, CA
- Website
- wsgphotography.com
- Can others edit my Photos
- Photos NOT OK to edit
Someone else posted a few days ago about their shutter not actuating in the cold after a while of use and I responded that mine did the same, we both cocncurred it may have been a low battery but today after shooting 200 frames mine stated doing it again!
What it does:
I snap off 6 or 7 frames while holding the shutter release at first stage, or half way down. Without releasing the shutter it just won't respond. Letting off the shutter release and pressing does nothing for about 10 seconds. Buffer indicator say 16, but it certainly acts as though the buffer is full.
Shooting 14-bit RAW
Continuous Focus mode.
Battery is full enough
Buffer appears ready
Focus indicator shows this > < not locked but it doesn't matter if I'm in Continuous or Single focus mode.
Only seems to happen after shooting a while but I may just perceive that, I may be snapping faster frames as I tire...I mean as the shoot gets into the 3rd hour.
What should I look for that I'm not?
EDIT 1/03/2012 SOLVED!! THe on board flash I use to trigger the CLS system was the culprit. It will allow 6 or 7 rapid shots and then need recharge....Doh!! Answer is to be patient or use another SB-800 as a commander but that would bring the weight up on this beast to like 9lbs. Radio trigger is the real solution!
What it does:
Shooting 14-bit RAW
