Cameraclicker: Are you aware that
depth of field in the close-up range is basically independent of lens focal length, and is instead dependent pretty much on MAGNIFICATION of the subject matter? Yes, it's true.
You mention how things ought to be able to be measured....but as I mentioned above in my reference to the Bob Atkins article on Depth of field, depth of field behavior can be categorized into three zones: 1)
the CLOSE-UP zone 2)Intermediate distances and 3)Longer distances.
Again, as I mentioned earlier, depth of field behavior can be broken down into three different "types" of situations/shooting conditions. Your example of the three focusing targets demonstrate one of the anomalies that I mentioned above, some 70 posts back, that in the close-up range, DOF is dependent upon MAGNIFICATION of the subject, and lens focal length becomes basically....totally irrelevant. Weird, but true.
The reason your three-card focus chart shows basically the SAME depth of field is that it is a CLOSE-RANGE shot, and depth of field is caused because the three subjects have been reproduced at the same magnification.
Maybe look into the science of it. Here's what I mean.
Close-up
When the subject distance
approaches the lens focal length, the focal length no longer is negligible, and the approximate formulas above cannot be used without introducing significant error. At close distances, the hyperfocal distance has little applicability, and it usually is more convenient to express DOF in terms of magnification. The distance is small in comparison with the hyperfocal distance, so the simplified formula
can be used with good accuracy.
For a given magnification,
DOF is independent of focal length."
emphasis mine:
DOF is independent of focal length. Your shot of the three cards pretty much PROVES the theory, which you seem to have been unaware of...
from
Depth of field - Wikipedia, the free encyclopedia
As you can see, Depth of Field is broken down under section 10 and 11 into sub-sections dealing with the different ways DOF behaves in close-up, moderate, and longer distance scenarios.
