Tinderbox (UK)
- Joined
- May 1, 2010
- Messages
- 747
- Reaction score
- 120
- Location
- England
- Can others edit my Photos
- Photos OK to edit
I have wondered for a few years, just as with cpu`s the smaller the process 22nm normally the less power it uses, than the equivalent size chip a few years ago, My Intel Atom cpu uses 2watts and give the same performance that a 25watts cpu 10 years ago.
So as flash memory card sizes get larger, the manufacturing process gets smaller just to be able to fit it on the card, not to mention new 3d transistors giving higher data density's.
Have you ever take a lot of continues photo`s and removed the flash card and noticed it is very warm, even hot, all that heat is wasted energy, eg shorter battery life.
So retire that 8gb flash memory from 5-10 years ago and get a new card from a recognized manufacturer, I use Samsung or Sandisk as the quality is the best, and are much more resistant to damage have had cheaper cards fall apart.
Anyway i would like to hear you opinions on the subject.
Maybe we could test by using an eternal card reader on an notebook and write a few gb of date and then checking the temperature using a infra-red thermometer, hot is bad.
Thanks
John.
Thanks
John.
