Does someone make a.......
Discussion in 'Photography Beginners' Forum' started by Brutus Hedgeapple, May 26, 2008.
  1. Brutus Hedgeapple
    Brutus Hedgeapple TPF Noob!
    Feb 15, 2008
    4
    South Central KY
    ....a mount to put on my monopod so I can turn the camera from horizontal to vert or vice versa?
    If I knew what to call them, I'd do a search :confused:
    Thanks.
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    yes, it is just a tripod head. i have one on my monopod.
    i will check over on B&H and get back to you with the number.
    you could also consider a "joy stick head" which is very easy to switch.
    i just checked over there, look over pan and tilt heads for tripods. i didn't see the one i am using right now, but when i get a chance to go out to the car i will check on the model number of the part.
  3. Brutus Hedgeapple
    Feb 15, 2008
    4
    South Central KY
    Hey Thanks!!
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    You could use something like THIS.
    Or a Mini ball-head like THIS.
  5. KD5NRH
    KD5NRH TPF Noob!
    Apr 26, 2008
    308
    Stephenville TX
    Walls.
    :greenpbl:
  6. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    With my monopod I just hold the camera on its sid and cradle the monopod in the crook of my shutter arm (the one attached to the shutter finger). If the camera moves, it's only because my whole body moved.
  7. ann
    May 14, 2007
    4,263
    189
    i am using model 3229 bogen head on a monopod.
