DOF?
Discussion in 'Photography Beginners' Forum' started by tehbuffalo, Jun 13, 2006.
  1. tehbuffalo
    tehbuffalo TPF Noob!
    Jun 7, 2006
    191
    What is it/ how do I use it?
    Jake!
  2. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
  3. spike5003
    spike5003 TPF Noob!
    Jan 5, 2005
    364
    Syracuse, NY
    ok dof or depth of field is a functuion of aperature or f stop.. The higher the number the smaller the aperature and the greater the dof. Dof is the amount of the photo in focus from front to back. Things like flower macros look better with a shallow dof therefore wide aperature (low f number) and things like landscapes look better with a wide dof therefore small aperature (high f number). Experiment with DOF because in photography rules are made to be bent or broken. Try it and see what looks best.
  4. Ringo
    Ringo TPF Noob!
    Jun 6, 2006
    37
    MT
  5. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    Excellent descriptions/links for DOF by everyoneÂ… The only thing I would add is that the plane of focus within a given depth of field extends 1/3rd in front of the subject in focus to 2/3rds behind.
  6. fotogenik
    fotogenik TPF Noob!
    Jan 16, 2006
    345
    Louisville, Kentucky
    The descriptions for both images at the bottom of the page state they were both done at f3.5, but you don't really explain what the difference in the photo's is. I can tell the difference is what you focused on, however in a tutorial you should probably explain this, especially when the tutorial is being written for a beginner.
    Cheers,
  7. Ringo
    Ringo TPF Noob!
    Jun 6, 2006
    37
    MT
    I believe it actually does state the difference in the description under the image. The point I'm getting across with those two images is that just because you know how to use depth of field, doesn't make an image any better, as illustrated by the second image. It's obvious to me, but I've been doing it for quite a while. Thanks for giving a new perspective.
    Now, enough thread thievery! :D
