70to210mmf4
- Joined
- Jun 27, 2019
- Messages
- 53
- Reaction score
- 3
- Can others edit my Photos
- Photos NOT OK to edit
That's exactly the information I needed; thank you! Where on earth did you find that?
The RS-35 looks somewhat like the M600. So what follows is based on my M600.
The bulb screws into the M600 from the top.
Below the head, there is a tube-like assembly where the power cord goes into the head. The top of this assembly is where you screw the bulb into.
Twisting that tube-assembly lets me push/pull, to adjust the vertical position of the bulb in the head. The tube assembly is friction fit/not threaded, twisting it just makes it easier for me to move it up/down.
If the manual says to twist it. The assembly might be threaded, rather than friction.
The Durst illuminates from the side of the bulb, so you have to adjust the vertical position of the bulb to give you even illumination on the baseboard.
The PH-211 is a 120v bulb.
Worst case, look for a 75 watt, WHITE bulb, without any printing on the side.
Although if it prints too short, you might look for a lower wattage bulb. A 75 watt bulb in my M600 results in an exposure less than 10 seconds, which is almost too short. I wanted to get a 40 watt bulb, but they don't make a photo bulb that low.
Thanks; that is very comforting to know that I can pick bulbs with different brightness to suit my situation. If a 75 or 60 watt bulb is too bright I will try a 40 watt one. Of course, I may just have a problem with my darkroom or I did something wrong to the paper. I forgot about ND filters; I didn't know you can get them that tiny, that they will fit on an enlarger lens.
If you're going to use filters, diffusers and whatnot, I'd suggest keeping them above the negative. Otherwise they can degrade the image. I wouldn't attach any filters onto the front (paper side) of the lens.
If it is optical glass filter, I would not have an issue putting it on an enlarger lens.
So you don't place filters onto the front of a camera lens
