Filter question
Discussion in 'Photography Beginners' Forum' started by 250Gimp, Oct 18, 2006.
  1. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    This is probably a dumb question......:confused:
    I have a UV filter on my lense now. Do I leave it on and put the other filters on, such as a circular polarizer or close up filter, or should I remove it and put each individual filter on?
    Cheers
  2. cosmonaut
    cosmonaut No longer a newbie, moving up!
    Oct 12, 2006
    1,122
    98
    North Georgia
    No, take it off. It will cause dark areas around the picture. It's not a dumb question. I learned the hard way....
    Cosmo
  3. Remi M.
    Remi M. TPF Noob!
    Jun 25, 2006
    279
    Vancouver, Canada
    You will get viginetting as cosmonaut said. Also Circular polarizers and some other lenses have also block UV.
  4. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    i always leave my UV on no matter what. its just a part of my lens
  5. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    It's much cheaper to replace a scratched filter than a scratched front lens element. Since you have a circular polarizing filter, I suggest you put it on your lens and leave it there. While the UV filter will serve the same protective purpose, its effect on a picture is usually nil. The polarizer, on the other hand, will help many shots.
  6. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Stacking filters is usually a bad idea. Not only can it cause vignetting as mentioned above but it can also introduce contrast robbing flare. Leave the UV in place until you need another filter, then remove it, use the other filter and replace the other filter with the UV again.
  7. JTHphoto
    JTHphoto TPF Noob!
    Jul 22, 2005
    4,387
    73
    Phoenix, AZ
    I used to leave my UV filters on all the time like fightheheathens, but over the last year or two i have been taking it off for all the reasons listed above... vignetting at wider angles, flare, etc.
    Also, it seems to me the more glass you shoot through (especially if dirty or poor quality) the less your images will be sharp/clear.
    If you use your close-up filter & the UV, you will get different results because the filter is further away from the lens, and it basically works like a magnifying glass.
  8. W.Smith
    W.Smith TPF Noob!
    Oct 11, 2006
    440
    Every added filter adds 2 refractive surfaces to the lens array: the front surface and the back surface of the filter. Every refractive surface increases the risk of glare and flare. I.o.w. use as few filters as possible.
    Virtually every other optical filter also filters UV light (you don't get a tan behind a window!). I.o.w. a UV filter in combination with any other filter only increases risks and downsides, and doesn't add anything useful to the party.
    So use UV filters by themselves only. Never combined with other filters.
  9. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Thanks everyone, I will be using one filter at a time.
