First HDR c&c please
Discussion in 'HDR Discussions' started by IDLaxStar, Aug 29, 2010.
  1. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    This is my first attempt at a HDR picture. I just wanted to see what others think of it or what i should do different. Thanks guys.
    [​IMG]
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    there seems to be a small amount of halo issues between the roof and the sky.
    how many exposures? i would like to see some details in the shadows within the barn.
  3. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    Yeah i know. I wish the shadows in the barn had more detail too and i took 7 photos, and what do you mean halo issues?
  4. Bynx
    Bynx No longer a newbie, moving up!
    Feb 8, 2008
    2,804
    366
    Just outside Toronto Canada
    The haloing is almost unnoticeable. If this were a perfect picture I would make note of that but there is the problem with the shadows. Not enough detail. You might want to try to put the picture through Shadows/Highlights. That should do the trick.
    [​IMG]
  5. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    Here is another hdr i just put together, this one seems a lot nicer to me. What do you guys think?
    [​IMG]
  6. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    the halo over the barn is so minor I wouldn't really worry about it now the sky portion needs an adjustment and as others mentioned shadows & highlights. Nobody else has noticed is a bit off horizontal center as well. I am making reference to the 1st image.
  7. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    The white's are blown out, some minor halo's around the clouds itself and either some alignment issue and or chromatic aberation is going on around the portions of the tree my bet is on alignment issue which can be corrected with a mask layer using the tonemapped and one of your properly exposed originals.
    Trust me take this as a compliment your images are not bad compared to some of the ones I have seen through out various sites.
    I rather look at this one compared to what came out of the crayola factory I seen lately on another site. That image is so over saturated
    basically it glows in the dark if you get my point.
  8. Bynx
    Feb 8, 2008
    2,804
    366
    Again, the point of HDR is to give some detail in both the brightest and darkest areas. Ive just put your image through Shadow/Highlight to bring out the details in the shadow areas.
    [​IMG]
  9. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    Ok thanks for the help. I will keep practicing this. I will hopefully have another good shot soon. Thanks for all the help
