First try at Green Screen
Discussion in 'Photography Beginners' Forum' started by chrisburke, Feb 20, 2009.
  1. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    i went out today and bought some green fabric.. please know, i know this picture sucks!!! it was a very quick shot with my one flash.. i just wanted to try it out... i know there is a little bit of green spill in her hair.. i'm working on how to get rid of it all easily.... (any mac program suggestions??? other than photoshop.. anything dedicated for greenscreen is what i'm looking for)
    before:
    [​IMG]
    after:
    [​IMG]
  2. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    27
    Brooklyn, NY
    pretty good. What method did you use to remove the green? Magic Eraser or the color range option?
  3. chrisburke
    May 25, 2007
    2,107
    i used the magic wand and increased the threshold to make it get as much green as possible... (i think you were the one asking about this earlier this week.. i put a video link in your post on how to do it..
  4. Jaszek
    Oct 7, 2008
    2,177
    27
    Brooklyn, NY
    yep that was me lol. I use the color range. It grabs more of the green.
  5. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    Not bad...but ya, you have to watch out for the green spill. If you can have the model get farther away from the BG, that will help a lot.
    As for how to do it...there are many, many different ways to do it in Photoshop. Google extraction or cromakey + photoshop.
  6. chrisburke
    May 25, 2007
    2,107
    thanks for the tip mike.. i did have my bride really close to the screen... like i said, it was just a quick "i wanna test this out" sort of situation.. but your tip helps greatly!!!
  7. chrisburke
    May 25, 2007
    2,107
    just looking at a photoshop plugin by digital anarchy.. called primatte.. it seems pretty easy to use... expensive though.... or ... well... you know
  8. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Could be better in my opinion. The background just doesn't look clean. I would say blurring the background more would help. Or use something that doesn't have a pattern to it like paper. Color Range is definitely the way to go by the way. There are some good tuts on the net for this as well.
  9. chrisburke
    May 25, 2007
    2,107
    ^^^^like i said.. i know its crappy, its just a quick test...
    so I just used Primatte (by digital anarchy) and this edit literally took me 3 minutes to do starting with the original green screen image...
    [​IMG]
  10. goodoneian
    goodoneian TPF Noob!
    Apr 6, 2008
    528
    temecula, ca
    just curious but what's the benefit of using green fabric over any other color? can't you do essentially the same thing with white or black or am i missing something
  11. Jaszek
    Oct 7, 2008
    2,177
    27
    Brooklyn, NY
    Well you use either green or blue since your model will probably not wear those colors. You can use other colors but green is used the most. Also if you use black and the models hair is black then you have a problem ;)
  12. chrisburke
    May 25, 2007
    2,107
    the reason why you use green or blue is because they are the furthest away from your skin tones
getting rid of green spill in photoshop
green screening banned
northernrebel wear
