Flash and Stroboframe
oooOOOoo something is strange...
Just looking at the EXIF data from photo #1. According to the exif data, there was no flash detected. All the other photos have flash, compulsory listed.
surprisingly I think that makes since to me!
should I be able to see the preflash? Or is it so fast that I shouldn't be able to tell the difference?
I guess I should just call my supplier and see if they can either fix it or send it back to canon and get a new one if it would be a defect.
Thanks for your help!!!
There is obviously something going on. If the exif data says no flas detected you have a problem with your cord. If it were me I would send back the promaster and get the Canon. And I would tell them that the Promaster was not working for you to try and save some of the shipping costs.
ok, so I just saw your other message! So pretty much it is a big problem with the flash???
ok, so I think I may have figured it out???
I went and looked at the pictures i took yesterday of the girl....and it showed that the flash fire each time it was supposed too...
So that confused me even more....
well, I got my equipment all set up again and retook the very first picture that i posted w/ the stroboframe and the picture turned out exactly like it should w/ the flash. And it worked several times!
So, I am going to assume that it was my error and something wasn't connected good enough the first time when I took those pictures. But, If for some reason that wasn't the problem and it happens again soon then I am going to send this promaster cord back and get the canon.
Seems like a long way around a stupid error, but I have learned along the way and I would always prefer human error over equipment errors!!!
Thanks so much!!
I'm not so sure that you can see pre-flash. It's generally 70-150 milliseconds before the metered flash.
I was dealing with sync. issues and tried a point and shoot, which also didn't work. Until I read that it also used Pre-flash.
Went to an old flash unit, shoe mounted, which wouldn't pre-flash, I couldn't see any difference, except of course in the photos, which now have the fill flash, in Sync. with the camera flash. :thumbup:
Here's the answer to EOS metering modes and flash. They all react differently.
http://photonotes.org/articles/eos-flash/index2.html#confusion
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]On most if not all EOS cameras, P mode is not shiftable when flash (internal or shoe-mounted Speedlite) is used.
[/SIZE][/FONT]
I can definitely see it. It is pretty obvious if you trip the shutter a few times looking at the subject and not through the viewfinder.
You can also test to see if E-TTL is working by hiting th exposure lock button.. you should see a preflash go off (but not the main) to allow the camera to meter and lock in an exposure.
