Flash & Lens Recommendations?
Discussion in 'Photography Equipment & Products' started by Sbuxo, Jan 9, 2010.
  1. Sbuxo
    Sbuxo TPF Noob!
    Aug 29, 2008
    978
    6
    Hey, I have a photo-project for my photography class and I will be doing low-light (b&w film) portraiture. I have a Konica Autoreflex TC with a 50mm 1.7 lens, but I am thinking of getting the 135mm 3.5 telephoto lens...will that be an okay lens for the type of photography I want to do? Also, I need to buy a fairly inexpensive flash (budget: 60-75$), my professor suggested Sunpak and someone told me the Sunpak 444D would be good for my camera. Anymore suggestions/comments about this flash or any others? Of course, I'll be getting a diffuser as well. The typical setting for my project will most likely be indoors, so in/around the house or in a bedroom. I'm looking for a hot shoe flash, by the way. I'm new to using flash :blushing: but hopefully you guys can help me? :) I'm hoping to buy by this Monday or Tuesday.
  2. max123
    max123 TPF Noob!
    Jan 9, 2010
    4
    Maryland
    Both lens and flash should get the job done for you....
    MaX
  3. Sbuxo
    Sbuxo TPF Noob!
    Aug 29, 2008
    978
    6
    both that i mentioned or...?
  4. iolair
    iolair No longer a newbie, moving up!
    Oct 4, 2009
    508
    61
    Exeter, England
    I would find 135mm a little long for indoors portraiture (but a good option for outside) - is there an option about 100mm available?
    Also, a maximum aperture of 3.5 won't let you isolate the subject from the background using a small depth of field as well as a faster lens might.
    That flash should be fine for you, however for best results you'll want some way to modify the light (such as a small umbrella and stand).
