Flash Question
Discussion in 'Photography Beginners' Forum' started by swmocity, Mar 7, 2009.
  1. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    i have a canon 430 ex flash...i have a question about the manual mode. i know how to change the power of the flash...1/64, 1/32 ect...but what exactly is the zoom function...i have been taking picture with different zoom setting but they all look they same...should the zoom on the flash match the zoom on my lens?
  2. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    The zoom function is kinda self explanatory if you think about it. It allows your flash to cover the output of the lens you're using. For instance, if you're using a 28mm lens and set your flash accordingly, the flash will spread the light for the appropriate coverage, vice versa at the tele end.
  3. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    If you're using the flash on-camera and firing the flash straight ahead then yes, the zoom should match the lens.
    If you're bouncing the flash off the ceiling, use a shorter distance setting if the ceiling is low and a longer distance setting if the ceiling is high. Same if you're bouncing the flash off a side wall.
  4. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    You can be creative using zoom. Longer zoom narrows the beam.
