Flower Shots
Patm1313
Northeast US
This is a thread where I will put all of my pictures of flowers.
More to come.
5
6
7
8
9
10
11
12
13
14
15
16
Wow those a pretty
You should number them when there's more than two or three so people can comment.
I like 4 and 7 pretty good. I lose easy count after that tho so the one's further down which I liked aren't added.
Ok, I'll do that with my next set of pics. I can't really edit my post because it turns tags into pictures and I can't add lines between them.
u should be able to edit ur op to put spaces in between. if u put ur cursor above the first pic and use the arrow key u should be able to move the curson in between the pics and add a space. hope that makes sense! :sillysmi:
OK, the OP is now fixed. :)
Woo hoo! U have some pretty flowers there. My only bit of advice would be to research the rule of thirds if ur not familiar as all of ur pics have the subject dead center, and to try some other angles as most seem to be shot downward from directly above. :sillysmi:
I had plenty of pics that were shot from different angles. I actually took about 300, but only these 16 made the cut. Sadly, all of my odd angle pics weren't good enough.
