Focus problems with macro setting
Discussion in 'Beyond the Basics' started by Alex06, May 20, 2006.
  1. Alex06
    Alex06 TPF Noob!
    May 4, 2006
    533
    Southern California
    Hello all,
    I recently started having focusing problems with my Sigma 70-300 DL macro super. It's the lens that came with my camera and it's driving me batty. When I use it on the macro setting it makes a strange "I'm struggling to focus but can't" sort of noise. It used to just snap into focus. I've had the lens for a year and this just started happening recently. I tried to search the threads for an answer but couldn't find any. Any ideas? Thanks in advance for the help ;)
    Alex
  2. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    are you sure that you arent too close to the subject, or close than the minimum focus distance? it will just focus on and on if you are. that might be the problem...also make sure that you're focusing on something high-contrast, as the lens won't be able to find an edge to focus on otherwise. does it only do that in macro mode?
  3. Alex06
    Alex06 TPF Noob!
    May 4, 2006
    533
    Southern California
    Yup. It seems to only do it in macro mode. I know I'm not too close because I can focus it manually. But you're right- it makes the same sort of noise it would if I were too close. When it does it I try to focus on other stuff that should be easy for it to focus on. It just won't focus on anything at all. (Though not for lack of trying.)Thanks for responding so quickly!:)
  4. LaFoto
    Feb 1, 2004
    34,814
    816
    Lower Saxony, Germany
    I have the same lens and learned from the start that it only works manually when in the macro setting, so you find me very surprised at your describing you worked it on Auto Focus for a year! :shock:
    When I switch my Sigma 70-300 DL Macro Super into macro mode, I also HAVE to go into manual focussing! Always. Forever (and this is my second lens of the kind, the first becoming quite unreliable after a time).
  5. Alex06
    Alex06 TPF Noob!
    May 4, 2006
    533
    Southern California
    Wow that's strange. I'll have to try and find the instruction manual and see if that's normal. I assumed it wasn't since it's never done it before!
