Framing Photos C&C
Discussion in 'Photography Beginners' Forum' started by Rockern1, Mar 23, 2010.
  1. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    Hello
    Well since I failed miserably in my last Photoshop attempt I decided to take it slow. Today I checked out how to frame Photos and this is what i made please tell me your thoughts about it please.:D
    [​IMG]
  2. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    If you do a "stroke" blending between the image and the mat, adjust it to about a 5 pixel and grey color "inside" or "center" then do a drop shadow between the mat and the frame it will look more like what you're going after. This looks like the image is floating above a frame. Nice image though.
    This is assuming you wanted this type of effect:
    [​IMG]
  3. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,971
    Cleveland, Ohio
    I don't mind framing like this, but the shadow is bad.
    If it were matted, you could have a very small shadow on the image from the matte.
    The hovering image is "odd". It also makes the image look off center in the frame.
  4. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    I like the image, but I do not like the frame - remember, it is just my opinion.
    Black is a good color for the frame, maybe remove the white, shade it with gray and move the black frame up against the photo.???
  5. KmH
    Apr 9, 2009
    38,742
    5,159
    Iowa
    Because of the drop shadow it looks like the image is closer to the viewer than the frame is.
    Instead of a drop shadow you should have a inner shadow just inside the black frame.
    You can also make a beveled mat or double mat for the image using the Bevel/Emboss layer style on a very thin canvas. (I use the "Relative" option in the Canvas size dialog box.) (An outside Stroke leaves rounded corners.)
    Here is a double mat and I also used Bevel/Emboss on the brown frame. Notice the inner shadow just inside the left frame arm. I had the light here at about 160°.
    [​IMG]
  6. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    thanks guys good info ill try your suggestions:drool:
