Vtec44
- Joined
- Nov 13, 2008
- Messages
- 3,501
- Reaction score
- 1,917
- Location
- So Cal
- Website
- www.jamestangphotography.com
- Can others edit my Photos
- Photos NOT OK to edit
It is a Nikon mount, and will fit on FujiFilm S2 Pro, S3, S5, and pretty much all digital Nikon cameras and most of Nikon film cameras. It is a non-AFS lense. It is in pretty much perfect shape, no scratches, moisture, or fungus on the lenses (front and back). It comes with a UV filter, circular polarizer, front and back lense caps, and a sun hood. The lens was made in Japan. I'm shooting mostly landscape pictures now, so I don't really need this lense anymore. The retail price for this is about $400 without the UV filter and circular polarizer. I'm asking for $250 shipped.
From http://www.bobatkins.com/photography...00_review.html
The Tamron SP AF 28-300/3.5-6.3 XR Di LD Aspherical (IF) Macro is a general purpose lens for both digital and film cameras. On a film camera the 28-300mm range covers everything from landscapes through portraits to wildlife. On a typical APS-C digital camera, it has the same field of view as a 45-480mm lens would on a full frame 35mm camera.
The Tamron SP AF28-300/3.5-6.3 XR Di LD Aspherical (IF) Macro is a Tamron "Di" lens. Di lenses designed with digital SLRs in mind and Tamron say that they have higher resolution, better control of flare and ghosting, less light fall-off and lower chromatic aberration than earlier designs. Note that the Tamron SP AF28-300/3.5-6.3 XR Di LD Aspherical (IF) Macro lens, although designated as digital ("Di") has full frame 35mm coverage. It can be used both on APS-C sensor DSLRs and on full frame digital or film cameras.
The Tamron SP AF28-300/3.5-6.3 XR Di LD Aspherical (IF) Macro is remarkably small and light for a 28-300mm lens. In fact Tamron state that it's currently the world's smallest and lightest 28-300mm zoom.
Some specs:
Model Number A061
Lens Construction (Groups/Elements) 13/15
Angle of View 75°-8°
Focal Length 28mm to 300mm
Maximum Aperture f3.5-6.3
Diaphragm Blade Number 9
Minimum Aperture f/22-36
Minimum Focus 0.49m (entire zoom range)
Macro Mag. Ratio 1:2.9 (at 75mm)
Filter Diameter 62mm
Weight 420g
Diameter x Length 73mm x 83.7mm
[URL="http://www.pixlode.com/upload/af66_DSCF2593.JPG"][URL="http://www.pixlode.com/upload/af66_DSCF2593.JPG"][URL="http://www.pixlode.com/upload/af66_DSCF2593.JPG"]
[/URL][/URL][/URL][URL="http://www.pixlode.com/upload/2778_DSCF2594.JPG"][URL="http://www.pixlode.com/upload/2778_DSCF2594.JPG"][URL="http://www.pixlode.com/upload/2778_DSCF2594.JPG"]
[/URL][/URL][/URL][URL="http://www.pixlode.com/upload/c079_DSCF2595.JPG"][URL="http://www.pixlode.com/upload/c079_DSCF2595.JPG"][URL="http://www.pixlode.com/upload/c079_DSCF2595.JPG"]
[/URL][/URL][/URL]
Some specs:
Model Number A061
Weight 420g
[/URL][/URL][/URL]
