Gimme Everything You've Got
Discussion in 'Critique Forum Archives' started by Lycanimanomaly, Aug 16, 2006.
  1. Lycanimanomaly
    Lycanimanomaly TPF Noob!
    Aug 16, 2006
    26
    Bristol, TN
    Hey everybody,
    I've been into photography for the past year 1/2 and everything that I've learned has been self-taught. This'll be my first photo critique and I want you to give me everything you've got. I want to get good enough to become a freelance photographer. So what do you think?
    [​IMG]
    I took this with an Olympus D-595 Zoom.
    This is me and my ex.
    We're sitting on a large vine that's naturally endowed with 2 seats. There was a tree on either side of us (you can partially see the tree on the right) and I wanted to get both trees in the shot to frame everything but somehow i failed to get the left one completely.
    Anyway, I'd love some good constructive criticism on this. Thanks!
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Well the first thing I noticed was that she has a tree growing out of her head.
    I can kind of see how you were trying to frame it with the trees...but I think it would work better if you cropped closer. All the stuff around you isn't adding much so get rid of it.
    It's a little soft and grainy (noisy)...most of which is probably a limitation of the camera.
    I do like the sepia tint you have here, and the whole concept of you two sitting on the vine. It's a nice moment.
  3. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Yeah I agree with Big Mike... I think cropping it to be a vertical shot might help clean it up a bit and put the focus of the shot and you and your ex. Not bad though...
  4. Lycanimanomaly
    Aug 16, 2006
    26
    Bristol, TN
    ok i've made the suggested changes.
    I was so comfortable with the original version of this pic that i'm not sure if the changes i've made look right.
    In addition to cropping it i also brightened it a bit.
    Don't know if i can do anything about the noise.
    What do you think about the changes?
    [​IMG]
  5. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Personally I like it better just because it draws the focus to you and the girl.
  6. Lycanimanomaly
    Aug 16, 2006
    26
    Bristol, TN
    Thanks alot for your suggestions. you rock. :)
  7. Philip Weir
    Philip Weir TPF Noob!
    Apr 29, 2006
    506
    Sydney, Australia. The land of peace and sunshine.
    It's one of those shots that needed soft light to set the mood, but I appreciate you have no control of the light....or do you !!!
    It would also have been better if you got further back, used a longer lens and pulled focus [shot wider aperture] to seperate the subject from the background.
  8. Lycanimanomaly
    Aug 16, 2006
    26
    Bristol, TN
    ok i've given it a soft-focus effect. I'm not sure that the end result is the same as if i had manipulated the actual light before i had taken the picture (as this manipulation is digital) but I think it amplifies the mood a lot more.
    Could you *or anyone* give me an example of what pulled focus looks like?
    [​IMG]
  9. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I'm not familiar with the term "pulled focus" but I think Philip means that a shallow DOF (Depth of Field) would have helped to accentuate the subjects by blurring the background.
  10. Lycanimanomaly
    Aug 16, 2006
    26
    Bristol, TN
    ok. i see. i think that's all the work i'm going to do on this photo. thank you for your critiques.
  11. MDOMINIC
    MDOMINIC TPF Noob!
    Aug 18, 2006
    I think if you want strong opinions post this in the 'people photography' forum on www.fredmiranda.com.
  12. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    If you were using an SLR with a depth-of-feild preview you could have focused the subjects as close to the end of the range of focus at whatever f/stop you were at and that would have reduced the DOF even MORE!
    What I mean is that if you shoot at say.. f/8, than you'll have about 6 feet worth of depth (probably not, but it's just for the sake of example). If you focus at the end of that 6 feet, you'll have very little depth of field and your subjects will really pop out. however, anythign 6 feet between the subjects and the photogrpaher will be in pretty sharp focus.
