HDR questions
Discussion in 'Graphics Programs and Photo Gallery' started by MyaLover, Jan 28, 2008.
  1. MyaLover
    MyaLover TPF Noob!
    Nov 13, 2007
    876
    Here and There
    Can you do HDR photos in PS? If so, how? Or is there a special program needed? Lastly, could you do something that looks similar to HDR in PS? Once again, if so, how?
  2. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    what version ps do you have?
  3. MyaLover
    MyaLover TPF Noob!
    Nov 13, 2007
    876
    Here and There
    Well I have PS and image ready, both version 9.0
  4. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    in that case its - File > Automate > Merge to HDR
    If you can't see it you may need to click 'show more menu options'. ;)
    • Funny Funny x 1
  5. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
  6. MyaLover
    MyaLover TPF Noob!
    Nov 13, 2007
    876
    Here and There
    Wow, thank you for your help and quick reply!
  7. MyaLover
    MyaLover TPF Noob!
    Nov 13, 2007
    876
    Here and There
    Everytime I try, PS gives me this message that says " there is not enough dynami range in these photos to contruct a useful HDR" How do I fix that?
  8. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    I get the same thing
  9. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    you need to use shots with different exposures... ps doesnt like the 1 raw with different version outputs. ;)
  10. MyaLover
    MyaLover TPF Noob!
    Nov 13, 2007
    876
    Here and There
    Heres what Im doing: Taking a picture, then making 2 or 3 versions of it in PS by altering the exposure in PS. Attempting to make the HDR, but it is still giving me that message. How can I fix this?
  11. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yea making different versions of the same shot won't work in ps... when it says "there is not enough dynamic range in these photos to contruct a useful HDR" it is saying that becuase the images aren't from seperate exposures it can't increase the dynamic range. (you may be able to edit the shots to loose the exif data and trick PS but its not worth it)
    So, there a few things you can do... one is to re-shoot, use a tripod and get say 3 exposures of the subject changing the exposure each time. So you end up with one correct exposure, one over and one under.
    Bring the shots into ps and dont alter them in any way (if your shooting raw make sure they dont get the auro correct treatment) and save as tiffs. Then PS will recognise them as usable HDR images.
    The other way is to download Photomatix (or similar) and just use the free to try version (you'll get watermarkes but its good for practice). This will give you more noticable HDR results, and you can try it with the 2 or 3 versions you made in PS, but this is not true HDR and will only give you a certain amount of dynamic range to play with.
    For the strongest HDR results and to create the almost 'cartoon' look use the shooting method i suggested above and use Photomatix set to the strongest settings.
    I should really sticky one of these threads.... if anyone wants to add links etc do so here and i'll stick it.
  12. bango707
    bango707 TPF Noob!
    Sep 23, 2007
    124
    Downtown LA
    I think that is a great idea! The more information we have in an easy to locate thread would be ideal! :thumbup:
