Histogram... How important?
roadkill
Atlanta GA
Appearantly histograms seem to be really important. Call me amature (I am) but if by your eyes, you come to your desired effect and out come of your shot... who cares about what a histogram says. I am an extremely zealous student, and sometimes I get frustrated by these things that seem to make no sense to me. Is it a measure of what is correct in some standard set by someone? If the shot comes out how you want, then I don't understand why you would have to measure yourself against this.
Well, we worked without histograms in the film era. On the other hand (having come into digital about a year ago), I have come to love them. They make it alot easier to decide whether you have the information in an image (correct exposure) that will do what you want it to do when you sit down to PP it. If your shots always come out how you like (boy do I wish ....) , the histogram is superfluous.
If the shot comes out how you want then yes. To get that correct exposure (no matter what you are after) many people use the histogram to aid them. If (as your avatar shows) you are after an underexposed shot with lots of black, then the histogram can be used - where you are looking for more of the graph to be on the left hand side. The opposite is true if you were aiming for a highkey shot.
The other reason is that the histogram on a camera is more acurate at showing you areas over over and underexposure than the viewfinder preview of a shot - its also much quicker to glance at
I only see the histogram in pp. I compose the shot, (whether I want to over or under expose) then I shoot it. I guess I rely on my eyes and intuition as well as what I want to achieve in each particular shot to gain the outcome that I want. Doesn't veiwing a histogram say to you guys "Hey? Did I match my shot with what this thing says it should be?
I'm not trying to be obstinant or ignorant (I am) but if this thing can help me to develop my art I certainly would like to be privy on how to take advantage of it.
sort of it is matching it to what something says it should or should not be, but that person should be you the photographer.
The histogram can be set to show on image reivew and that is where I view it - I very much do use this in the field with changing light to make sure that the shots I take are not being blown out or underexposed too much. Of course experience of different shooting conditions and environments can give one enough to be able to guess at the results without looking, but it takes a lot of real time to reach that point.
Its a tool and it can help you get what you want though you have to learn to read it and then understand what it is saying and then make sure that it is saying what you want it to say (as opposed to saying what others think it should say)
We've already had this discussion. Use the search function.
I did use search. came up with a lot of useless crap
Figured I would get right to the point with folks who cared to respond.
All it tells you is the distribution of tones from pure black to pure white. If you find that useful, then use it. If not, don't.
Histograms aren't new. They're just newfangled and technically speaking, more accurate but in a sense harder to read. You can use a good external light meter to make a histogram using reflective readings. It basically ends up telling you the same thing but with fewer data points (and I might add, only the important ones if you know what you're doing).
Why would that be useful to anyone?
Thanx guys, for your response. You have supported what I had origionally suspected.
I always use my histogram. Am i going to try to convince you that its better or worse? no. For me, when trying to adjust or fine tune the exposure, i use the histogram to make sure their is no clipping. If there is, i pull up the review thing were it blinks the clipping to see what it is i blew out and if i care to fix it (if its important or not like a spec on the shirt or something off in the background that would be pointless to fix without messing up something else)
A lot of times on my D200, the screen will look fine when in reality i blew out the whole shirt or something
The histogram is a tool, like the light meter, the aperture preview function and the Swiss Army knife. It has a specific function, and can be useful, but is by no means essential. My opinion is: If they're going to give me tools which can help improve my pictures, I'm going to use it.
Histograms are not there to tell you whether your image is perfectly exposed, they're there to tell you if you've achieved your desired effect because a 3" screen usually can't.
