It was outdoor.Well, where are you shooting? It won't do much indoors (except maybe with reflections), but bring it outdoors and you should see major changes as you rotate it.
Because most sensors will overexpose the sky to white or near-white when the subject is properly exposed. A CPL can compensate by darkening the part of the sky behind your subject. It's not always possible or desirable to do post-processing HDR.If normal looking sky is the purpose then why use a polariser?
What brand/model of filter are you using? That could make a difference.it is a very minute effect it seems, but I did see it work (done it in my mirror and removed a highlight on the reflection.
