In addition to the above solutions for the object itself, If you have lingering dust in the air the best solution to eliminate the floating dust is to add humidity to the air. I have other hobbies where I need humidity, such as woodworking. The humidity essentially makes the wood dust just fall to the ground and not linger in the air. It actually keeps the room clean.
This is easily accomplished by getting a cheap CVS/Vicks warm mist humidifier for under $20 and setting up near where you don't want dust. Also get a small digital humidifier gauge so you can see how low it is. You'll want it above 40% in the area.
and make sure the objects are all clean before hand as mentioned.
Use a small soft paint brush to get things in the cracks.
