How to Ghetto-Rig my backdrops?
Discussion in 'Photography Beginners' Forum' started by keith204, Jan 23, 2008.
  1. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    I know they make stands, but I don't really want to spend $130 on something at the moment. So, I'm looking for ideas on how to rig this thing up.
    2 10x20 backdrops (black, white)
    My wall is 8ft tall, and about 10ft wide. I am able to screw things into the wall if necessary, and I am certainly up for a project.
    Requirement:
    Be able to switch between black/white rather quickly
    Any suggestions?
  2. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    How about a handful of thumb tacks?
    Or you could put some grommets in the fabric and some nails in the wall to hang them from.
  3. dpolston
    dpolston TPF Noob!
    Apr 8, 2007
    949
    Norfolk, VA.
    I thought you posted this?!?
    I would buy a piece of electrical conduit and 2 utility hooks (4" handy hook) from a local hardware store. $10.00 tops!
  4. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    Ah I think I remember this response to another topic now. That sounds like it'll work great! Thanks so much for the advice! PERFECT!
    Man you guys rock, as always.
  5. Emerana
    Emerana TPF Noob!
    Jan 2, 2008
    857
    Houston, Texas
    attach a large curtain rod to the wall :)
  6. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
  7. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
  8. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    Get a long curtain/shower rod maybe a tension fit if you can find one long enough. or the utility hooks and conduit,
    and a bunch of shower curtain rings, than put both backdrops up, and slide back and forth to change them.
    It might be a pain to put lots of holes and grommets in the backdrops, but at the restaurant where I work, be put up a large curtain to draw in front of the buffet, so while the band is playing the kitchen can shut down the buffet from the other side. We used rings with little clips that clipped to the curtain, to avoid putting in grommets.
    The clips are like ID badge clips, like the ones with the ring on the top.
    http://images.google.com/imgres?imgurl=http://www.badge-lanyard.com/badge-clip/im/badge-clip-8.jpg&imgrefurl=http://www.badge-lanyard.com/badge-clip.htm&h=367&w=576&sz=32&hl=en&start=5&um=1&tbnid=1XDRZju3_cXDZM:&tbnh=85&tbnw=134&prev=/images%3Fq%3Did%2Bbadge%2Bclips%26svnum%3D10%26um%3D1%26hl%3Den%26safe%3Doff%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:eek:fficial%26sa%3DN
    I'm not sure where we got them , In sure it was local, and knowing my boss I'm sure it was cheap. They hold surprisingly strong if you slide from the rings rather than the curtain.
  9. Happy Hour
    Happy Hour TPF Noob!
    Dec 5, 2007
    453
    Chicago IL
    My hubby is a electrician and he bent up some thin wall 4 me with shower curtian hooks. it works flawlessly and collapses in seconds to store in the closet
  10. bango707
    bango707 TPF Noob!
    Sep 23, 2007
    124
    Downtown LA
    it seems everyone on here is using pvc to make little softboxes so why not use some to make a stand?
  11. boomersgot3
    boomersgot3 TPF Noob!
    May 15, 2007
    273
    Illinois
    I used some aluminum rods at lowes. They wre like $4 for a 10 ft pc and I had them cut them the length i need. I then use C hooks or I suppose you could use Hook and I hooks and I just rest the pipe in the hooks. I got tech'cl and drilled holes inthe pipe and placed them over the hooks so they couldn't fall. But I deal with only children. My New studio Will have a suspended enclosed system but for not this works great! And yes-I did purchase a $250 background stand from B and H when I first got started. I never use it except when I do In home sessions. HTH!
building a wedding backdrop with electrical conduit
ghetto backdrops
ghetto backdrops photography
how to rig a backdrop
how to rig backdrops
muslin backdrops houston
photo backdrops in houston
photography backdrop houston
photography backdrops houston
what are grommet rings on backdrop for
