How?
Discussion in 'Film Discussion and Q & A' started by doobs, May 22, 2008.
  1. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Did this happen?!
    This is not a multiple exposure.
    [​IMG]
  2. yellowjeep
    yellowjeep TPF Noob!
    Mar 21, 2008
    267
    Lawrence KS
    No idea, but its very interesting
  3. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    did you have a filter on your lens? I was getting strange reflections the other night while using a cheap UV filter on my lens. took the filter off and problem was fixed
  4. Seefutlung
    Seefutlung TPF Noob!
    Apr 13, 2007
    1,558
    62
    SoCal
    Did your lens have a UV filter? This could be a ghost image caused by reflection from poorly or uncoated lens elements or filters.
  5. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Yeah, after developing the negs, a few of the shots of this same structure thing all looked the same. This was the most drastic. I thought it was interesting and i was kind of wondering how it happened.
    It was shot with a Pentax K1000 equipped with a SMC 50mm f/2 (fully open at f/2) loaded with fresh T-Max P3200 shot at 3200, if that's any help.
    EDIT: Yeah, there probably was a UV filter on it. Interesting.
  6. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,036
    508
    L.A.
    That's a new one on me.
    There was nothing else between you and the subject? Like a window?
    I don't see how a filter would cause that unless (maybe) if it were mounted
    incorrectly, at an angle.
    I can only guess that the subject was a bright enough light source to cause
    an internal reflection within your lens or between the film itself and the lens.
  7. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    The only thing I could think of is that the light from the subject reflected from some surface inside the camera, possibly from the film itself, bounced from the rear element of the lens, inverted and rexposed the film. Just a guess.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Some lenses do this even without an IR filter. It's called ghosting and is a form of lens flare.
  9. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    I didn't have an IR filter, and the image was pretty bright. I was outside, and right under it. Only thing I could think of would be the UV filter, mounted correctly, which I usually always have in front of the 50mm.
