HTML - Rollovers
Discussion in 'Off Topic Chat' started by vonDrehle, Aug 31, 2005.
  1. vonDrehle
    vonDrehle TPF Noob!
    Jun 27, 2005
    430
    6
    North Carolina
    I am making a webpage for my eCommerce class. I just finished one of the rollovers and was wondering if I were to use several rollovers on the same page do I have to put in the entire code for each one or is there a short cut?
    I haven't started my site yet, just working on design, but here are the codes for the roll over.
    <!-- ImageReady Preload Script (Untitled-1) -->
    <SCRIPT LANGUAGE="JavaScript">
    <!--function newImage(arg) {if (document.images) {rslt = new Image();rslt.src = arg;returnrslt;}}function changeImages() {if (document.images && (preloadFlag == true)) {for (var i=0; i<changeImages.arguments.length; i+=2) {document[changeImages.arguments].src = changeImages.arguments[i+1];}}}var preloadFlag = false;function preloadImages() {
    if (document.images) {test_01_over = newImage("images/test_01-over.gif");preloadFlag = true;}}
    </SCRIPT>
    <!-- End Preload Script -->
    <body bgcolor=white text=red link=white vlink=white onload="preloadImages();">
    <!-- ImageReady Slices (Untitled-1) -->
    <A HREF="#"ONMOUSEOVER="changeImages('test_01', 'images/test_01-over.gif'); return true;"ONMOUSEOUT="changeImages('test_01', 'images/test_01.gif'); return true;">
    <IMG NAME="test_01" SRC="images/test_01.gif" WIDTH=63 HEIGHT=26 BORDER=0></A>
    <!-- End ImageReady Slices -->
    Thanks...
    And the only software we are currently using for coding is Notepad, Wordpad, or any other generic program you might use. So no "help" if you will.
  2. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,324
    102
    Poland, Sz-n
    oh gosh you have a mess in your code :) I am afraid I can't help youw ith this one but I'd suggest cleaning your code and organizing it in a more "readable" one...:
    rslt = new Image();
    </SCRIPT>
    return true;
    return true;">
    there's no help included but it is not so messy now... :p
  3. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
  4. vonDrehle
    vonDrehle TPF Noob!
    Jun 27, 2005
    430
    6
    North Carolina
    I didn't write it I just took it from image ready. ;)
    Thanks
    **And last night I worked a little more on it and I think I came out with something that should work.
