Ice hockey HELP
Discussion in 'Photojournalism & Sports Gallery' started by supermanning, Sep 19, 2010.
  1. supermanning
    supermanning TPF Noob!
    Jun 23, 2010
    28
    SoCal
    the season has begun! And I have been taking portraits all summer. Went to a game last night at a rink with possibly the worst lighting I have ever experienced. And WOW, these guys are fast!!! Using a 7D (new) with 70-200 2.8 IS. I was late, so didn't get a chance to WB the ice
    so, my questions: what do I loose if I increase my ISO 2000+
    I usually shoot AV, how do increase my shutter speed? Should I try shutter priority? It's hard to go full manual when they are moving soooo fast
    Any help appreciated!
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    The lighting should be fairly consistent, so once you establish the proper settings, full manual should be the easiest. All you have to do is focus and shoot.
    What do you lose by raising the ISO? Noise free pictures, lol! I haven't used the 7D though, so I don't really know what the ISO limit is for acceptable noise levels...
    If you're not comfortable going manual, Av will give you the fastest shutter speeds for the aperture you're using.
  3. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,334
    Way up North in Michigan
    If you're not going to crop them like mad, you can get aways with quite a lot of ISO latitude with the 7D, from what I'm finding on my own 7D rig.
    I find that my shooting habits are changing from shooting mostly aperture priority or shutter priority to full manual most of the time, now that I have auto-ISO and can get away with it without much to worry about on the noise issue. It's very liberating to be able to choose both shutter and aperture however I like for creative expression and let the camera decide what ISO to use to pull it off, and not worry much at all about noise issues associated with it anymore.
    If it were me, I'd put the ISO on auto-pilot, set the shutter at 1/250th (or faster if need be), the aperture at wide open for some sweet isolation and background bokeh, and start firing!
    Oh, and I'd definitely take a few moments to get a WB first. It's well worth it, IMHO, and doesn't take but a few seconds if you're practiced at it. If you're not practiced at it, what are you waiting for? It only takes a couple of times going through the steps, and you'll have it down pat.
  4. CNCO
    CNCO TPF Noob!
    Feb 4, 2010
    488
    7
    USA
    how did the 70-200 work for hockey? did you have enough length to capture everything? i might start shooting hockey for a team and i am just trying to get my equipment ready.
  5. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    If you're shooting RAW, you can take your WB reference shot after the action is over, or during a lull...
  6. supermanning
    Jun 23, 2010
    28
    SoCal
    CNCO, I purchased the 70-200 because of hockey. I couldn't imagine using anything else. (plus, now I use it for almost everything else)
    Ice Hockey is very difficult when you add in the horrible lighting, white background, and fast motion. Plus, you usually have to shoot thru marked up glass or netting.
    I've been "getting away with it" for the past year or two, but I really want to step up and do some great action photography. so, I need some great advice!!!
    I'm going to a series of games next weekend, then home for awhile, where I should have a crows nest view of the games.
    Buckster, In order to set a WB, I need to arrive before the players take the ice, so I can sneak in and get my settings.
  7. CNCO
    CNCO TPF Noob!
    Feb 4, 2010
    488
    7
    USA
    thats what i was wondering, how do shots look when you as a photographer have to shoot through the glass. does that dull the image? rinks should have platforms up high.
  8. Buckster
    Sep 14, 2009
    6,399
    2,334
    Why? The boards are white, the ice is white, lots of white all around most hockey rinks I've been to that will work to do the WB setup off of. Just zoom in on one, shoot it, and set your white balance to it. Done. It's like 20 seconds.
    And if you have an assistant (read friend or family member) with you that's willing to hold up a white balance tool like a gray card to do it, even better. It still takes all of about 20 seconds.
  9. supermanning
    Jun 23, 2010
    28
    SoCal
    I guess I thought I had to use the ice for WB settings... I'll try other options next time
  10. CNCO
    CNCO TPF Noob!
    Feb 4, 2010
    488
    7
    USA
    i would shoot raw or use the auto setting. me personally i have never used a grey card. im guessing all you do is shoot your lighting source with the grey card next to it and really try to differentiate white and grey?????
  11. Buckster
    Sep 14, 2009
    6,399
    2,334
    1. Let the light source illuminate the gray card. Doesn't have to be next to it - just lit by it. Overhead lights in an ice rink light up everything in the rink with virtually the same color cast, so you could put it on the floor at your feet and shoot it even.
    2. Shoot the gray card. Just zoom in on it, take the shot using just the rink lighting, and you're good to go. It doesn't even have to be in focus.
    3. Set the WB to use that shot as the source. If you don't know how to do this, see your manual. It's a couple clicks at best on the menu. Once you know where they are and how to do it, it's a total breeze. It will then use that WB until you tell it to do something different.
    4. Done. Shoot to your heart's content.
    The gray card is more reliable than random white sources for best accuracy, because random white sources can have their own color cast which we can't readily detect with out naked eyes, but can affect overall WB to the camera's more sensitive WB detection system. A photographic gray card has no such color cast issues.
  12. supermanning
    Jun 23, 2010
    28
    SoCal
    Great! I know how to set a custom WB, but, like i said, I thought I had to use the ice. I'll pick up a card, and try that for the weekend.
    Again, my question, if the lighting is poor, will I loose anything going for an ISO 3200? Can I change my shutter speed in AV?, or trust the camera
