Installing Nikon DK-19 eyecup
benhasajeep
Just received 2 new eyecups and decided to install them. Here are some pictures of installing one for those thinking of buying a DK-19 eyecup.
Close viewfinder shutter. Unscrew original eyepiece counter clockwise.
Original eyepiece and new DK-19 from package.
Remove metal ring from DK-19.
Flip original eyepiece over so threads are up.
Remove original rubber ring from eyepiece.
Start to instal original eyepiece into new DK-19 eyecup. Make sure threads are up.
Eyepiece fully installed in new DK-19 eyecup.
Install metal retaining ring over new eyecup and eyepiece.
Clean the glass on the eyepiece before installing. Screw eyepiece with DK-19 eyecup open onto camera clockwise until slightly tight. Open viewfinder shutter before collapsing new DK-19 eyecup.
New eyecup opens and collapses with just a push around the outside.
I have an adapter to install that same one on my D610. problem is, when I use a strap it ALWAYS catches and falls off. and second is, after about 3 years of use it started to split where it flips back around -- so I need a new one:
